Greasing lower ball joint?
Old Mar 10, 2025 | 12:25 AM
Triaged's Avatar
Default Greasing lower ball joint?
I've got
LockNLube LockNLube
Grease Gun Coupler and an https://www.rockauto.com/en/moreinfo.php?pk=1023237 for the idler arm bracket. Greasing most of the joints is now simple except for the lower control arm ball joint. The LockNLube is just a bit too big in diameter to fit right. Any suggestions on how I should take care of that? Should I put a 45° grease fitting on it? What are the grease fitting threads? M6?
They really didn't think about service when placing the grease fittings!
Old Mar 11, 2025 | 7:59 AM
Derrick71's Avatar
I believe the threads should be universal for the grease fittings. If you look the fittings up the thread size should be listed.
Ferrailleur Dans Le Placard
Apr 18, 2016 1:03 PM
magician
Jan 31, 2016 6:47 PM
cygvan
Dec 10, 2015 8:14 AM
Outlander 2004
Oct 17, 2012 9:31 PM
runningjalapeno
Jan 24, 2011 2:31 PM
