Harmonic balancer wobble/Belt squeel/ Belt slips
Replacing the crankshaft means pulling the engine and stripping the entire engine down to the bare block. I'd put a dial indicator on there and get a number to work from. Then pull the harmonic balancer off and check the crank for run-out too. You need a puller to remove it. Should get an install tool as well.
Lakeman 903
Nov 27, 2021 2:19 PM
