Have van can't travel
Old Mar 10, 2010 | 10:31 AM
brokevan's Avatar
Question Have van can't travel
I have a g-20 van with 5.7 1987 (350)
I have sunk lots of cash in this van this week. I still have same problem. Runs couple minutes then shuts out. Starts back up after a few minutes only to repeat.
Replaced: fuel pump in tank, fuel filter,fuel pump relay switch, ignition module in distributor, distributor cap, plugs and wires, temp. sensor switch, ignition coil, alternator and battery.
Thanks for any suggestions, I am at my wits end.
Old Mar 10, 2010 | 11:45 AM
maxxman04's Avatar
not 100% sure, but i know on computer controlled, the oil pressure switch is tied into the ignition. check the oil pressure gauge while running, see what kind of pressure there is. could just be a bad sending unit. maybe.
Old Mar 10, 2010 | 12:17 PM
brokevan's Avatar
Default thanks for the info
thanks i will give it a try
57hotrod
Feb 5, 2013 7:27 PM
okiecamper
Aug 11, 2010 12:57 PM
DeeZ
Jul 30, 2009 12:28 PM
larrygolf
Aug 11, 2006 1:00 PM
