Heater Core Replacement
Old Aug 23, 2015 | 8:33 AM
kit141a's Avatar
Default Heater Core Replacement
G30 Sport Van with the 5.7L. Leaking heater core. How hard. Any hints or help. Live in Northern Mn so cannot bypass
Old Aug 23, 2015 | 12:52 PM
Phillip123's Avatar
Well you want to change it yourself?
I hope this steps can help.
How To Replace a Heater Core
Old Aug 23, 2015 | 6:23 PM
canucklehead's Avatar
A Haynes repair manual has some more specific steps. While the dash is out, its time to upgrade the dash speakers or any gauge lights that need doing. Also check for loose clips and screws etc......you won't be going back in there again for a while....lol.
Old Aug 24, 2015 | 11:25 AM
kit141a's Avatar
Default heater core update
Thanks for the reply's. The You Tube not much help, as this dash has no glove box. The way the video showed I should have it out in a matter of minutes. Think they left out a few steps. Decided to do this myself, as I am retired and have some knowledge in the repair field. Besides the lowest quote was around $1300 which I am sure is not out of line with the amount of labor involved. I got it out after removing the entire dash and all the the other stuff. Not a lot of room. Waiting on a replacement core. As long as was under there, I looked at the control that directs A/C and heat to different locations. As of now the air flow only goes to the defrost no matter what position the slider **** is on. I think is might be some type of vacuum problem. Looks like I am missing some hose or plugs on the vacuum control. Does anybody know where there is a diagram of this vacuum control.
Hope I can remember where all the screws go. Can not believe they would use so many different sizes for the same purpose
Thanks
Old Aug 24, 2015 | 5:04 PM
Yeah, I know, I tried to find you better vids but they all sucked....
Glad you got it apart though....
Old Aug 24, 2015 | 6:32 PM
kit141a's Avatar
Getting ready to install. Took a few trips and different parts store to find the right core. With so many screws and steps sure hope I remember everything. Did take a few pics sure hoped that helps. Once again thanks One thing if anybody needs some advice on this, will be more than willing to pitch in
BC09Chevy
Jul 16, 2011 7:23 AM
HHR Ratt
HHR
Oct 22, 2010 9:14 AM
mdthomas26
Camaro
Jun 19, 2010 7:40 PM
H Frank
Oct 31, 2009 2:34 PM
RedBoat
Oct 18, 2006 3:19 PM
