Help !
Any ideas ??? I have 2 vans that intermittently will not start. They won't turn over, they won't do anything. If you let them sit for a little while then they'll start right up. I've replaced the ignition switch, battery, starter, checked battery cable & connections & they are ok. Anyone else have this happen ? Any suggestions ?
Steve.
Steve.
Hey Steve, Unfortunately I dont have an answer but do have the same problem with my 2009 Express. When its not working, there is .125 volts going to the starter, when its working, I get the full 12 volts. I too have replaced the starter and checked all connections (i have not replaced the ignition switch). I dont believe its a security issue because the security light isnt on. My vans lights and everything are fine but when turning the key to start, dead silence everything turns off. hopefully someone can help us. Travis
