Hot alternator stops charging?
Old Sep 3, 2020 | 7:47 PM
SteveROntario's Avatar
Default Hot alternator stops charging?
2004 Chevy Express 3500 6.0
I got my van hot while I was on city surface streets (the temperature was half way between 210 and max). Eventually I gave up looking for the destination and idled the van for a while trying to get my bearings. At one point I turned off the van for 10 minutes and when I restarted it the battery voltage was at 12. I turned everything off and reved the engine but it wouldn't go up. I shut things down and turned on my generator which has a trickle charger tied to the battery and was able to get the voltage back up to 14 after about 1 hour. No problems in a 1 hour drive after that but I'm concerned. Should I be buying a new alternator?
Cheers, Steve
Old Sep 4, 2020 | 12:22 AM
nope. Sounds normal.
Forcing the voltage up was just cooking the battery.
235 deg coolant temp isn't normal though.
https://chevroletforum.com/forum/upl...-drain-101952/
Old Sep 7, 2020 | 9:37 PM
It seems to be OK again. I put couple tanks of fuel through it and the charging is back to normal but I've lost some confidence in things. I'll have to carry my clamp-on meter with me and try to catch this again if it happens again.
Unca_T
12
Nov 25, 2020 4:04 PM
konstantinNeo
Feb 9, 2020 2:01 PM
davis.a.kyle
Feb 13, 2018 4:29 AM
99SuburbanTX
Sep 13, 2012 9:34 AM
wally3b4
Apr 8, 2011 9:59 PM
