How do I access the door jamb switch on 2009 Express 2500?
Old Dec 12, 2018 | 2:02 AM
  #11
dberladyn's Avatar
You wouldn't actually have to take your door panel off to play with this idea. Just hang on, I have to look at 2009.
https://www.gmupfitter.com/files/med...ans_100813.pdf
If you remove the kickplate in the driver foot well there will be an electrical harness connection. A connector for the Left Door Wiring Harness to plug into the Body Wiring Harness. It will appear intimidating and alien, but if you study it carefully, you can remove the coloured plastic locks, using a strong pin/pick (of your ability to find) you can remove each wire without damaging anything. Use the pin/pick to insert into the connector to release the wire. For each wire, there is a tiny hole or slot to put a tool to depress the lock that holds it in place. If you do this properly, you can remove the wire. In this way you can disconnect the wire to the door switch. The chime should turn off. If it does not - try grounding the wire. Since you will have the wire out and the metal contact exposed, this will be very easy to do.
Your older wiring scheme is different than mine. Given that it is older, the pins should be bigger and even easier to remove. You just have to find out which wire it is and the location of that wire on the connector. Unfortunately, for 2009 and the schematics are not as complete at GM Upfitters as they are for later years or I would have included a reference to the connector and the exact wire/location.
The Connector you want is here, where the arrow points. X500. There are two on my truck. Yours too I believe.
Connector X500 on my Truck. Pin A1. Tan Wire.
You might actually find that just disconnecting the Connector from it's other half (very easy to do) does the trick. You will not have left speaker or any power door items though.
Old May 28, 2024 | 2:53 AM
  #12
MrBryan's Avatar
I found this thread while searching for a solution,
and I just wanted to say that you were on the right track…. If you pull the pin out per that upfitter manual, that’s all you need to do. No need to ground it out or anything. It will no longer register when the door is open.
I have a 2009 Chevrolet express 3500 ambulance and it was actually pin C-12 for me on CX 318 the same harness location .
of course your stereo and dash lights will stay on for 10 minutes every time you turn off the car unless you turn them off yourself
now to wire a standard door switch in line.
aaric
Nov 3, 2020 6:15 PM
tskier
Dec 11, 2018 10:54 AM
sheridan1952
Mar 12, 2017 3:53 PM
Kevakasper
Sep 24, 2013 6:07 AM
bluemoon
Uplander
Mar 8, 2013 9:04 AM
