"I need one more inch"
Old Oct 5, 2019 | 12:03 PM
cjm1973's Avatar
Default "I need one more inch"
And it ain't no "that's what she said" joke.
My 2019 extended length passenger van is sitting about 1 inch higher than my garage door header. I originally wanted to park it in the garage during winter. Thinking about it over the last week, I thought there could be something done to the rear leaf springs to help lower it that inch. Stopped by a spring shop near me yesterday and the tech said he could "de-arch both rear springs" with option of adding in 1 additional leaf in order to prevent a "sag" when towing. He said de-arching won't reduce the spring capacity, it will just flatten out the arch, so a loss of 1 inch of suspension travel. Adding in another leaf will strengthen the spring pack in order for the van to be level while towing. The shop has done it many times as many owners request it for the same reason: garage clearance.
Anyone have thoughts or done this? Would loose about 1" of the rake while empty.
Old Oct 5, 2019 | 4:25 PM
oilcanhenry's Avatar
Smaller tires? Other then raising your garage roof or course. That would not be cheap unless you are good at carpentry.
Old Oct 5, 2019 | 7:50 PM
Irish_alley's Avatar
I'm here for the party
put hydraulics on the van???
Old Oct 5, 2019 | 9:02 PM
Beau Oszman's Avatar
Let a bit of air out the tires, reinflate when ready to drive again.
Old Oct 6, 2019 | 8:06 AM
what did the shop quote to bend the springs and install a leaf?
Old Oct 13, 2019 | 8:38 AM
cjm1973's Avatar
$249. About 3 hours of work he said. Still undecided. I really want to keep the van in the garage but I don't want be in a negative rake situation when loaded up.
Old Oct 13, 2019 | 3:16 PM
Tony vanore's Avatar
id say problem solved with this one lol. Won’t cost you anything but an air compressor or tire inflator if you don’t have one already.
Old Oct 15, 2019 | 2:13 PM
joelsplace's Avatar
As an added bonus it will force you to make sure you have the right amount of air in the tires before you drive it.
Old Oct 18, 2019 | 9:20 PM
LOL! It's funny as I once said I thought tire pressure monitors were as waste of time. I'd still use the feature. Then a few weeks back I used it, and had a small leak going
on in my left rear tire. It was 26 PSI and I always run 35-36 PSI. Sure enough I had a small nail in the tire. Needless to say I will keep the TPS system going in my 2015
Malibu..
Old Mar 2, 2020 | 11:53 PM
ray caldwell's Avatar
It's only your rear that's too high? Yall are only talking about leaf springs. If everything else is good drill another hole in your shackles or have machine shop make you shorter ones
booneylander
May 13, 2020 2:57 PM
Simon-Pierre Lacasse
Mar 8, 2014 7:18 PM
barwick11
37
Dec 5, 2013 10:45 PM
s34n
Aug 3, 2010 4:44 AM
lawsona
Jun 25, 2008 5:30 PM
