Installing amplifier in 88 G20 van
Trying to install an amp in my van, but i cant seem to find anywhere to stick the power wire through. Its roughly 1/2 inch in diameter. are there any holes already there i could use, or am i gonna have to drill?
depending where your putting it..i'd look around under the carpet and see if there any there...if not just drill a hole..make sure theres nothing underneath tho...run the wire up the framerail to the battery..also put some zipties over the frame and wire..
88cheveybeauville, You should be able to easily find a place to route your power wire if you remove the doghouse.
You might want to try routing it alongside the steering column or find another place where there is already a hole.
Just remember to use a grommet or ziptie it to something so it won't move around and cause a short.
good luck hope this helped
wsalopek
June 20th, 2012 9:46 AM
americano49
April 5th, 2008 3:12 PM
