Installing amplifier in 88 G20 van
Old Sep 26, 2010 | 7:02 PM
88cheveybeauville's Avatar
Default Installing amplifier in 88 G20 van
Trying to install an amp in my van, but i cant seem to find anywhere to stick the power wire through. Its roughly 1/2 inch in diameter. are there any holes already there i could use, or am i gonna have to drill?
Old Sep 26, 2010 | 10:42 PM
gotstylez's Avatar
depending where your putting it..i'd look around under the carpet and see if there any there...if not just drill a hole..make sure theres nothing underneath tho...run the wire up the framerail to the battery..also put some zipties over the frame and wire..
Old Oct 3, 2010 | 10:30 AM
Inca Orchid's Avatar
88cheveybeauville, You should be able to easily find a place to route your power wire if you remove the doghouse.
You might want to try routing it alongside the steering column or find another place where there is already a hole.
Just remember to use a grommet or ziptie it to something so it won't move around and cause a short.
good luck hope this helped
Nash
Oct 3, 2015 8:15 AM
wsalopek
Jun 20, 2012 9:46 AM
americano49
Apr 5, 2008 3:12 PM
Rescue30
Jul 29, 2007 10:17 PM
