Installing Tach in 1988 Chev 30 Van , Help
Old Apr 1, 2012 | 8:13 PM
oldman's Avatar
Default Installing Tach in 1988 Chev 30 Van , Help
Hi , I have a 1988 Chev that I want to install a tach in . It has a 350 with external coil. on top of the coil there are 2 clips with 2 wires . Each clip has a white and red wire . The green wire has to be attached to the neg coil wire . I cant see any neg or - mark on the coil . I assume the white wire would be the neg but one never knows . Also where should the wire be attached on the wire going into the coil or the wire between the coil and the distributor?
Is the white wire the one and which side of the coil ?
Thank You for any help
k1500yukonxl
May 24, 2014 7:57 AM
JLanzino
Nov 29, 2011 9:28 AM
bentwrench
Aug 25, 2011 5:52 PM
88cheveybeauville
Oct 3, 2010 10:30 AM
MistaRIPsta210
Dec 11, 2009 7:54 AM
