interior dome lights functional but not with doors
Old Jun 4, 2018 | 6:36 PM
hck2gh's Avatar
Cool interior dome lights functional but not with doors
2003 Chevy Express 1500 - Interior lights all work when turned on individually but do not turn on when doors are opened or using the panel switch. The panel switch was just replaced, all courtesy light fuses and relays checked.
Old Jun 4, 2018 | 8:41 PM
You can find wiring diagrams here:
BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
In my van, the bulbs that you turn on individually are not the same ones that illuminate when doors are open.
What about your manual dome light switch that turns them all on ... what does it do?
Old Jun 4, 2018 | 10:38 PM
hck2gh's Avatar
That switch is part of the panel we replaced (see attached). Both the button and dial depress. The dial turns. Nothing. Headlights work fine. . ..it clicks and we can hear the relay click.we'll look at the service manual tomorrow and see if there are separate bulbs but would be surprised that they died at the same time. We suspect at this point it's a wiring problem.
Old Jun 4, 2018 | 11:50 PM
to turn on dome lights, turn the small dial all the way to the right until it clicks into position.
the button on the left turns automatic illumination on/off.
Old Jun 5, 2018 | 8:17 AM
StanVan's Avatar
15 Year Member
And the button on the lower left is the override for the dome. When depressed, the lights don't go on with the door opening.
Old Jun 5, 2018 | 2:25 PM
That's what I said Stan
