Interior plastic panel removal (rear)
Old Oct 27, 2011 | 8:45 PM
TwoUnderPar's Avatar
Default Interior plastic panel removal (rear)
I recently purchased a 2007 Express 1500 AWD full size van and need to wire up trailer lights. I have already purchased a wiring harness with connectors that clip into the factory harness at the tail lights.
The process all looks very simple.... however, I need to remove the plastic interior panels in the back corners (that cover the tail lights/wiring) and also the overhead plastic panel above the back doors.
Any and all advice or tips would be appreciated before I start trying to pull things apart! Thanks!
Old Oct 29, 2011 | 7:04 PM
Well, I went ahead and installed my Hopkins wiring harness today. Everything went well and it turned out that removing the interior plastic panels wasn't too tough. They are held in by metal/plastic clips that separate easily as long as you use a long screwdriver (or similar) and pry them straight out. There was no damage done anywhere and they all re-snapped back into place when I was done.
The Hopkins custom wiring harness (from eTrailer.com) is pretty slick. It cost $60 and was delivered in 3 days. Snap, Snap, done... The eTrailer website also has a couple of video's that I watched.
Disclaimer: I have absolutely no connection with eTrailer/Hopkins. Just a satisfied customer!
Old Jun 3, 2022 | 11:26 AM
Sharon_Everidge@yahoo.com's Avatar
Default Removing rear plastic panels
How did you remove the rear plastic panel on driver's side? Tried using screw drivers but the part of panel closest to back door seems to be attached to something. I am afraid to apply too much pressure.
Old Jun 3, 2022 | 12:05 PM
only clips, just like TUP said. Unless somebody added something.
Old Jun 3, 2022 | 6:30 PM
Default Removed the panel
Thanks! It worked! Was just afraid to break it.
Old Jun 4, 2022 | 2:51 PM
William Kisselstein's Avatar
Almost all of the inside trim on these vans snaps into place. There is a speaker pod on some that bolts in - the fancy interior actually covers that with another piece. Sometimes the clip comes off the trim and sticks, you just pop it out and snap it back on the part.
My guess is as they age they will get brittle, particularly in hot climates.
The only other thing you have to watch is 97-02 door panels you slide up once the screws are removed. 03-up pop out like most other door panels. I know that's not relevant here, but wanted to mention it.
Fire69
Sep 16, 2017 8:21 AM
cycleops
Jul 14, 2016 11:26 AM
pervitizm
Mar 25, 2009 10:09 AM
Vox
Dec 22, 2008 7:47 PM
MountainMan71
Nov 15, 2007 1:25 AM
