Knock, knock, Who's there?
Old Dec 29, 2022 | 10:32 PM
Red78rooster's Avatar
Default Knock, knock, Who's there?
1995 G20 Van
Kind of continuing a situation from a previous thread about the cluster panel. I had every intentions on changing out my water pump when my engine developed a small knock. It would only do it when it was in reverse or drive and not park or neutral. As I took it to my mechanic to check out, He said that I did not have a water pump issue that it sounded more like a spark knock. Being that the Van is 30 years old I was unsure when the last tune up was done. As I begin to remove plugs wires I noticed that it had been a very long time since a
tune up had been done. I installed new spark plugs, Wires, distributor cap, and rotor button. That made a big difference on the vehicle, But I still have a slight knock. I don't think it is as bad now as it was, But it is definitely something that needs attention. Any help would be much appreciated.
Old Dec 30, 2022 | 12:50 AM
well if it only happens in certain gears then it's more likely to be drivetrain related.
Is this at idle, or rolling down the road?
Old Dec 30, 2022 | 2:39 AM
Sometimes as soon as I take off, sometimes I get a couple miles down the road.
Old Dec 30, 2022 | 1:44 PM
OK I would inspect the driveshaft U-joints. If it hasn't been lubed in years it could be binding or already worn out. Same with axle pinion.
Bad motor/tranny mounts can also get noisy.
Old Dec 30, 2022 | 4:08 PM
Going to try the knock sensor that is located behind the starter.
Old Dec 30, 2022 | 5:49 PM
So you think the engine is pinging? Try some premium fuel
Old Jan 3, 2023 | 7:08 AM
William Kisselstein's Avatar
Typically a loose driveshaft u-joint will make itself most known when you let off the gas at speed. Under load there's pressure on it so it doesn't vibrate.
ill4na8na2
Feb 9, 2015 10:36 AM
stcspiderman
Aug 17, 2010 12:26 PM
lgarner
Aug 26, 2008 6:39 PM
windpower79106
Nov 16, 2006 1:36 PM
