LED headlights
#41
I have installed 5x7 Autopal headlights and the cutoff is like OEM and I put LED bulbs and havent had any issues.
They are clear glass.
https://www.ebay.com/itm/200mm-H6054...cAAOSwu4BV05N2
#42
I think the factory spec headlights are engineered specifically to be as bright as possible without blinding everybody. When you need more, you turn on the high beams.
LEDs usually have ****ty spectral distribution (bad color) compared to halogen too.
#43
Wow they are actually blue.
Their website is pretty funny.
Autopal
So is there a gasket to keep moisture out?
Amaging Performance
Enhanced Light output
Elegance of blue lamp with light output of clear lamp
HID Colour Simulation
Higher Colour Temprature
Perfact White Light
Perfact White Light
#44
I had to cut some of the plastic to make room for the heat sink of the LED. After I had it install you can tell that the light needed to be adjusted down. I like how bright they are and also the color.
#45
#46
So I instelled the LED bulbs, they are really bright, and install was fast and easy.
But.... I got the finger from drivers in front of me at night with low beam. High beams were great as everything was lite up, but drivers coming my way, and the drivers going in the same direction i was going, in from of me, gave the finger.
I think they are too bright and not properly aligned, but how can I adjust light aim?
#48
Find a building or wall on level ground you can pull up close to. Using tape, mark the top of the beam. Back off 50 feet or so, and if the beam is higher, they need to adjust down. There are screws on the housing to adjust them.
#49
