Locking Differential?
#62
He painted his plastic parts on the top and sides of the rear
above the tail lights..
plus they are the vented style which are the older style.
I like mine smooth...
I am not sure what your referring to as YELLOW ?
#67
when you did make the change from 3.73 to 4.10
did you have ABS ?
Is there ABS in the rear Axle ?
I didnt look closely on mine to see if there was such a thing
I know I dont have Traction control... so I was thinking that I
did not have ABS in the axle just my thoughts process of elimination
but I know I have been wrong before.. lol
what about changing >Something < to recalibrate the speedo ?
did you have ABS ?
If you want correct speedo readings, the PCM has to be reflashed for the gear ratio change (dealer, EFILive or HPTuners needed for this. Basic Tech 2 isn't enough).
I actually have a 4.10 FF (non-locking) axle with 225k. miles for sale (San Diego CA) if anyone wants $500 + $200 shipping
#70
Where would I find the case number on my diff? Based on the pic of my rear end, and this chart;
Differential Identification | Gearhead Diva
I figure I have a GM 8.6(25). Powertrax makes a no slip for that rear end, but only with case numbers "Ending In 0748 and 0449". The other troubling thing is that all the vehicles in the app chart top out at 2500. Is this a concern?
I need to fix this. I can ill afford to do it, but I can't get stuck at some slippery boat ramp, or allow one lousy inch of snow stop me (AGAIN!!) Part of my frustration comes from being in an AWD for years. I expected a bit of loss of performance, but didn't expect going from 4WD to 1WD. I am not happy. I take solace in that I do have a stable of mechanics eager and willing to help me out. So, labor will most likely be beer and burgers.
