lower control arms
Old Apr 25, 2018 | 9:42 AM
habanerored52's Avatar
Default lower control arms
Hi all. I have 1987 G20 van that needs new lower control arms. I found some new but they want $182 a piece. Are there any pickup truck lower control arms that are interchangeable with the ones on my van ? Thanks for your help
Old Apr 25, 2018 | 11:59 AM
Can you just change the bushings and use the old control arms?
Old Apr 25, 2018 | 12:41 PM
StanVan's Avatar
15 Year Member
The problem with your thinking is that if there's a part from another vehicle that fits, it's usually the same part number and price.
Rock Auto has arms much cheaper, and bushings real cheap.
Old Apr 25, 2018 | 1:15 PM
Rock Auto has arms much cheaper, and buIshings real cheap.
I have thought about changing out the bushings but one of my main problems is when you put a Jack underneath the control arm, the ball joint wants to drop and I don't believe there is a fix for that, is there ? Also, I have checked Rock Auto and they do not sell the lower control arms for the G20 .
Old Apr 25, 2018 | 3:42 PM
StanVan's Avatar
15 Year Member
They don't actually call it a "lower"control arm.
https://www.rockauto.com/en/catalog/...trol+arm,10401
I don't know if engine size makes a difference. I chose 5.0.
Old Apr 25, 2018 | 9:45 PM
The ones Rock Auto sells are the upper control arms. I NEED the lowers which are completely different.
Old Apr 26, 2018 | 8:11 AM
StanVan's Avatar
15 Year Member
My mistake. They picture them upside down, making them look like lowers.
