Need hvac parts/vacuum line identification
Old Sep 13, 2024 | 11:20 PM
Expresscv's Avatar
Default Need hvac parts/vacuum line identification
This is on my 2008 express 3500 with a 6.0 motor
Want to replace all the vacuum lines anyway, they all seem brittle
But right now if you get on a the gas for a hill etc the vents stop blowing out the middle and go to defrost
so i got the little vacuum control valve? The $6 one and was going to replace it to start
there are 2 plastic type lines that run through the firewall under the dash, the other side of those 2 in the engine compartment both broke off, they have rubber fitting onto both of them, one goes to the small vacuum thing and the other to that bigger round valve with the green arrow
does anyone have a parts diagram or the name of the 2 wire bundle that goes through the dash there?
thank you
Old Sep 13, 2024 | 11:29 PM
Expresscv's Avatar
Here are the pics
Old Sep 14, 2024 | 1:36 AM
Expresscv's Avatar
Think i found it, hope it is not discontinued, will contact dealer in the morning
does anyone have suggestions on any other vacuum stuff to replace? I am doing all the lines there in that area and hopefully this air valve actuator harness
would like to replace any vacuum stuff in the engine compartment that can get old and crack like this
thanks
Old Sep 14, 2024 | 6:36 AM
Triaged's Avatar
See here. https://chevroletforum.com/forum/exp...-issue-117027/
Old Sep 14, 2024 | 6:57 AM
Expresscv's Avatar
Some great info in that thread, thank you
MR WIZARD
Mar 15, 2018 10:08 AM
RbJb
Oct 1, 2011 3:16 AM
RakerBill
Nov 19, 2010 3:14 AM
BigDaddyO
Oct 14, 2010 7:47 PM
mgnui
Mar 9, 2010 1:39 PM
