No signal to fuel pump relay
Old Oct 24, 2014 | 1:25 AM
rynmcdonald's Avatar
Default No signal to fuel pump relay… injector not firing possibly as well
I have a 1997 G series van conversion with a 5.7 L engine. Fuel pump is good because I checked it by jumping the terminals. It's getting spark. Even tried jumping the fuel pump while cranking the engine and it STILL didn't fire.
Had my father cycle the key so I could check to see if there's a signal being sent to the relay and got nothing. I'm wondering If the injector is firing inside the intake and if there is a way to check it. Which fuse is for the injector? Possible bad ECU? Rural gauge is all the way over past the "F" mark. Any help on where to start is greatly appreciated as we need this running before mid November. We are going on a trip through the Rockies
FYI - my father complained about it running ****ty before it completely stop running. I hope this will provide a clue as to what it could be.
Last edited by rynmcdonald; Oct 24, 2014 at 1:30 AM. Reason: Additional information
Old Oct 24, 2014 | 10:56 AM
canucklehead's Avatar
I think the fuse in in the block by the master cylinder.
Change your fuel filter also..
Old Oct 25, 2014 | 3:17 AM
Default ECU bad.
It has corrosion damage from water. What other ECUs will work with this van? Can I use one from a truck with the same size engine? Need to know ASAP. Thank you.
Old Oct 25, 2014 | 1:55 PM
The aluminum housing of the computer gets like that but doesn't mean the cpu is bad.....
BRB
Dec 28, 2012 8:34 PM
wunderson
Jun 25, 2011 10:23 AM
hunter10220
May 18, 2011 8:37 PM
mikee
Aug 26, 2007 10:38 PM
oneflatoniakid
Jun 18, 2007 10:30 AM
