Ongoing DRAC/VSSB Issue
Old Jan 22, 2020 | 1:42 PM
95vanman's Avatar
Default Ongoing DRAC/VSSB Issue
Hi Everyone,
I am still having issues with my DRAC/VSSB on my 95 GMC G2500. I figured it's easier probably just to give you the facts first.
I first had an issue with the common symptoms of a bad DRAC/VSSB and/or VSS a little after 100k (when these all go bad from what I've seen), where the first thing I did was replace the VSS, where the issues remained. I then ordered a used replacement, with no history on this unit. I installed it, and everything worked perfectly for a few thousand miles, where my issues came back (no speedometer and only having 1st gear/possibly 2nd).
With this, I assume that the used unit's time ran out, and it now too needed replaced. I decided to forgo the mystery used unit route again, and decided to spend the big bucks on the refurbished unit (UD Module). I received my unit in a timely manner, installed, and no change.
I at first, was thinking that there was an issue with this refurbished unit, however, I soon came to the realization that it may be possible that the first (used) DRAC/VSSB I purchased, may still be fine, and that something else is wrong. I don't know at this point.
1.) Has anyone ever had an issue with the UD Module refurbished unit?
2.) I noticed only one of the two plug sockets are being used on my vehicle's DRAC/VSSB module, which is what I recall from before (it has been some time though), or should there be a second plug dangling somewhere under the dash that I am overlooking?
3.) If this all checks out, what should I look at next?.... Is there a fuse associated with this at all by chance?
Old Jan 22, 2020 | 11:25 PM
You may be having trouble with the speed sensors themselves. They do act up sometimes. Otherwise I would ask the experts at UD Module for help.
Contra
2014 - 2018 (GMT-K2)
Jan 3, 2020 12:45 AM
1963novaconvert
Nova & Chevy II
Jan 11, 2017 11:33 AM
harrim
Jan 7, 2015 1:51 PM
PaulR
Apr 20, 2008 8:46 AM
