opinion? on mixing different type of caliper grease
Old Mar 18, 2019 | 5:13 PM
tbb2's Avatar
15 Year Member
Default opinion? on mixing different type of caliper grease
Due to issues around the brakes I am looking to add to or change the caliper pin grease.
One video source recommended not mixing different types of grease and thoroughly cleaning the caliper pin pockets before adding grease.
That one source is the only place I see this. But it fits my thinking on keeping the machine clean.
I purchased the van used, and have no idea what may have been used in the past to grease the calipers.
Anyone have a view to this?
Old Mar 18, 2019 | 5:15 PM
kevinkpk's Avatar
I use just a synthetic grease, high temp.
Old Mar 18, 2019 | 5:35 PM
I don't see how it would be a problem. Grease is thick so it doesn't really mix. Just buy "brake grease".
Old Mar 19, 2019 | 10:05 AM
GatorHawk24's Avatar
Use a high-temp "brake grease" as other's have suggested, and be careful not to get it on your pads or rotors. It really doesn't take much grease to do the job, one tube could do several cars.
I don't think that "mixing" grease is really a problem, but you might want to do a thorough cleaning anyway. The pin grease can get really dirty and tacky, which will reduce the caliper's ability to move freely. Plan to use a few cans of brake cleaner because it can be difficult to get the old grease out of the caliper.
Old Mar 19, 2019 | 7:25 PM
I have only seen swelling issues when I worked for Nissan and a generic lubricant. gm parts will sell you the correct lubricant if your worried.
Old Mar 20, 2019 | 11:52 AM
tbb2's Avatar
15 Year Member
I will go the clean and replace route.
Old Mar 20, 2019 | 3:07 PM
kevinkpk's Avatar
Even sometimes with using grease on the pins to keep from seizing, they sometimes still seize, then you have to use the blue noised wrench.
Old Mar 20, 2019 | 5:16 PM
tbb2's Avatar
15 Year Member
Default mixing different type of caliper grease ... If there were grease!
Big lot of worry on mixing grease.
There was very little at all on the pins.
A copper colored paste came out of the base of the pin pockets.
I wounder if 'whoever' used copper anti-seize on the pins?
I see a, much belated, all around disassembly, cleaning and lub in my future.
On the subject of pins ... they are supposed to be perfect cylinders aren't they?
The top one has three equal flats evenly spaced around the circumference of the pin.
Old Mar 20, 2019 | 7:46 PM
some techs use anti seize but I think its a mistake for caliper pins....cakes up. they manufacturers don't use anti seize so neither do I
Old Mar 22, 2019 | 2:01 PM
The flat areas are normal. They provide a relief for additional grease to remain around the pins.
