Power window issues
Old July 7th, 2024, 9:52 AM
LeroyB's Avatar
Default Power window issues
Hello fellow forumers, I have a problem, the electric windows on the passenger side only go down.
From the driver's side, the passenger window cannot be operated at all.
When I have connected the blue white wire connection according to drawing, it goes down, I connect a separate wire to the connection where the all-blue wire has to go, then it goes up.
When all connections are connected, it doesn't do what it's supposed to do.
Both side window switches are new from te box and they work
no broken wires
windowmotor opperate in both ways.
So i do not know where to start from anymore
Somebody can put me in the right direction?
Chevrolet G20 Sportsvan 1984 5.0 V8
Old July 7th, 2024, 10:04 AM
Triaged's Avatar
How do you know there are no broken wires? Did you test for continuity? In my Saturn I had an open wires inside the door hinge accordion. I ended up cutting out and replacing enough in each so the splice wasn't in the bending area.
I used some silicone lube to pull the new wires through the rubber and the below crimper and butt connectors. I have no connections with these vendors, it's just what I found for a good price at the time.
haisstronica 6PCS Crimping Tool Set - Ratchet Wire Crimping Tool haisstronica 6PCS Crimping Tool Set - Ratchet Wire Crimping Tool
22-16 AWG Heat Shrink Butt Connectors 22-16 AWG Heat Shrink Butt Connectors
mountainmanjoe (July 8th, 2024)
Old July 7th, 2024, 10:14 AM
LeroyB's Avatar
Hi thank you for the replay, i tested it for continuity and the brown wire and the full blue wire.
Wich are connected to the power window motor.
the other wires Pink-brown-Tan-white blue seems in good condition no cracks folds or whatever.
if a broken wire has broken inside the insolation then this wire will do antyhting or is there a slight possibility that some times it make contact so there is a electrical connection?
Old July 8th, 2024, 12:02 AM
can you post the drawing please
Hnagle3054
September 24th, 2024 8:52 AM
Schroeder
May 28th, 2015 8:32 PM
gulfcoastjoe
July 25th, 2011 9:31 PM
jensen85
February 11th, 2008 12:03 PM
drewsm3
July 26th, 2006 9:22 PM
Quick Reply: Power window issues
