Question... GM 6L Instrument gauges read
Hello folks...
I am looking at/considering a used GM van purchase... I am starting to look at the Instrument cluster... I would like to know what readings a healthy 6L engine should be showing on the gauges...
Once upon a time I knew this stuff but I have been driving small import cars with idiot lights so I kinda lost touch with what actual gauges should read.
One van I like is reading:
Oil Pressure 30
Engine Temp 210
Charging System 16
Are these good readings for the 6L..?
Thank you
Oil Pressure 30
Engine Temp 210
Charging System 16
Thank you
That's about where my '16 is. The oil pressure will rise over 40-45 when revved. I monitor "Coolant Temp" with an OBD device. See this thread;
https://chevroletforum.com/forum/exp...-thread-87881/
I also monitor voltage, among other things, and mine sits upper 13s to mid 14s, so the one you posted seems a bit high.
Just looked it up in Rock Auto, and the ACD(listed as OEM) was 190. The gauges on the dash don't seem to be all that accurate. My dash says 210, but my ELM says 200-205. I'll try and get a pic of that screen the next time I'm out.
Thanks guys but I missed the window on that purchase...
But…
I have come across another one that has my interest…
It’s a nice clean looking (no real signs of abuse) 2002 passenger model, 5.7L with almost 160k miles… So that would be around 10K miles annually… Also, no signs of a tow hitch used.
Anybody have a guess on what the life expediency on this engine and transmission might be?
Thank you
Mike
But…
Thank you
Mike
I'd need service records to say. It's difficult at that mileage. The price would be the determining factor on a 16 year old vehicle. I would just say that I just got out of a '00 in July that may not have made it back home from the dealer I got my '16 from. And I did the recommended services.
That being said, I'm a confirmed GM guy. I wouldn't buy anything but a GM. I'm just a bit old to do the work myself.
