RPM drop shifting from drive to reverse
Old Jul 27, 2015 | 7:10 PM
CADru's Avatar
Question RPM drop shifting from drive to reverse
2009 Express 2500 6.0L V8 - 95,000 miles
What would cause engine RPM to drop when shifting trans into reverse? At idle engine is at 600 RPM, when I shift into reverse the idle drops to 250-300 RPM. The engine actually stalled on one occasion. Where would you start to diagnose this condition? MIL is off. No DTCs from my hand-held scan tool.
Old Sep 27, 2019 | 2:37 PM
Jsimmons2248's Avatar
Default How'd you make out
I have the same issue with my Silverado 3/4 ton new trans replaced almost everything under the sun did
you ever figure it out?
Old Sep 27, 2019 | 3:17 PM
Kael's Avatar
Something similar when shifting to Drive from Neutral?
Old Sep 27, 2019 | 3:37 PM
When u shift from drive to reverse when warm my rpm drops and seem like truck wants to stall
Old Sep 27, 2019 | 4:10 PM
Kael's Avatar
Okay, try N to D, same?
Think OP was referring to Park->R.
Old Sep 28, 2019 | 6:23 AM
If the transmission temp is about 180F it'll drop rpm from 600 to about 300rpm but recover. When temp reaches about 140-150F when I shift from drive to reverse ( like backing into parking spot or driveway) RPMs will drop also will recover on its own or can throttle it and keep it from dropping.
Old Sep 28, 2019 | 7:03 AM
Kael's Avatar
Check tranny fluid. If just changed, make sure the right fluid was used and is at correct level.
I'm assuming engine tune, etc. is fine, otherwise drive would have the same problem. Possible the tranny is not spinning freely as it should for the first few seconds after shift to reverse, maybe heavy fluid or gunk.
Old Sep 28, 2019 | 7:26 AM
Fresh fluid just rebuilt in March fluids good ,drives me nuts had tranny scanned and everything internally works good , hoping it sorts itself out.
Jul 26, 2014 11:43 AM
10267412
Jul 25, 2014 9:13 PM
BigBlock'Burban
Oct 5, 2011 3:53 AM
Buck Shaw
Jul 1, 2011 3:30 PM
bildojuice
Feb 10, 2010 10:10 AM
