Seats - Bolt right in
Old Nov 17, 2018 | 1:06 AM
dberladyn's Avatar
Default Seats - Bolt right in
Ok. I seem to go full circle with all of my ideas. Since the seats are actually decent (for my comfort), if I keep having a hard time finding something I like at a reasonable cost, I will just determine that I already have the best option. Factory vinyl manual seats. I installed the factory wiring for power seats, but I can never find the mechanisms at a low enough cost. The one time I could have pulled them out of a van being wrecked I was too lazy. I probably do not even want power seats, but I keep looking. Anyways, I would like a list of seats that simply bolt right into the factory pedestals. I have a hard time believing that Savana/Express seats are the only GM seats that fit this bolt pattern.
Not confirmed but I think the following bolt right in:
- Astro / Safari seats
- Malibu seats
I really have no idea, no confirmation, but is there anyway we can get a real list going? Surely it would help everyone?
Old Nov 17, 2018 | 1:48 AM
That's a no.
https://chevroletforum.com/forum/exp...-drawer-91965/
Old Nov 17, 2018 | 9:18 AM
StanVan's Avatar
15 Year Member
Just spitballin' here, but I would think that seats for cars might be a different height than seats for vans. Yes,I'm aware of the pedestal making van seats sit higher. But the interior height in a car is limiting. That, and vans (and trucks) have a stiffer ride, so added seat cushion could come in handy.
Old Nov 17, 2018 | 10:46 PM
dberladyn's Avatar
Spitball away! As long as it's not in the face...
I am going to digress and just accept that this bolt pattern only works with Savana / Express. I think I had read the older GM Vans have seats that bolt right in, but I'll probably be wrong at that too. Meanwhile, I think I am going start dreaming of ideas on how to make my cab look like this one.
Old Nov 18, 2018 | 10:30 AM
StanVan's Avatar
15 Year Member
I like the idea of a center console, but I like the ability to move to the rear better.
Old Nov 18, 2018 | 12:14 PM
I'm with Stan. The cockpit in your photo gives me claustrophobia.
Old Nov 18, 2018 | 6:32 PM
dberladyn's Avatar
Well, for how I am suppose to be using this van a console is already earmarked for construction. It has just been near impossible to get into the position to build all of this stuff. It was not using the van for work, if it was a camping truck, or a passenger wagon I would side with you guys. I am going to have a bulkhead separating the front from the back. I had a nicely shaped and painted piece of 3/4 plywood but I took that out as I would to be able to recline my seats. That is where my headache is. Designing it all to work for maximum usability, for the from as a passenger and for the rear as a work platform. I wish the swing doors were different. Either further back or the large door towards the rear and the small one up front. I don't know, I guess it would all lose aesthetics if that was the case.
Old Nov 22, 2018 | 8:17 AM
GatorHawk24's Avatar
A junk yard is obviously the most affordable option (if you can find what you are looking for), but this is the best price that I could find for an aftermarket powered seat base.
https://shop4seats.com/rv-furniture/rv-bases/class-a-rv-bases/6-way-power-base.html
I haven't verified the bolt pattern, but its something I'm considering. My biggest problem is that the collapsed height is 4 inches, according to the specs. Adding that on top of the stock seat riser will raise the overall seat height. I'm tall, I need it to be lower, but still raise up to accommodate my wife (the 1.5 inches of rise still might not be enough)... So, it will likely require additional fabrication, unless I find an alternate seat with a shorter bottom...
I know some on this forum have successfully replaced their front seats, but I'm not sure if any of their projects were direct seat-for-seat swaps.
Old Nov 22, 2018 | 12:15 PM
dberladyn's Avatar
Real-Estate here really took off and all of the wrecking yards that I was familiar with closed up. There used to be lots of them. Now the only ones I know of are an hour away. When I phone they either have no Savana/Express'es in stock, or it's just some optionless cargo beast that has been gutted. I find a good place to look is Craiglist. From time to time, someone seems to wreck their vehicle and for whatever reason it is sitting at their home or lot getting parted out. That was the only place I found power seat bases for an affordable cost. They are on Ebay new from time to time for around $250. Then you still need to find the wires, switch base and switch plate. The cost is not worth it.
Old Nov 22, 2018 | 8:10 PM
StanVan's Avatar
15 Year Member
I pulled power seats out of my '93 Astro to go in my '00 Astro, and the switch stuff was all part of the base.
