Secondary Batery
Old Oct 15, 2018 | 8:17 AM
GeneveConversionVan's Avatar
Default Secondary Batery
Hello All,
So Im planning to install a secondary batery for the electronics in my travel Van (screen, playstation, Blueray, etc) and I found information for the oem batery tray, but not for the rest of the OEM diesel installation (wiring, isolator, fuses) How is the diesel secondary batery connected?
Old Oct 15, 2018 | 10:46 AM
LCAC_Man's Avatar
direct parallel connection, no isolator, no fuses
Old Oct 15, 2018 | 10:50 AM
So simple and functional that its boring.. LOL
Old Oct 15, 2018 | 1:41 PM
StanVan's Avatar
15 Year Member
Okay, try this one on for size. On some gas models, a second battery is energized in to the system by a relay that senses a charge from the alternator. This is done so a depleted aux battery won't drag down starting the engine. I don't know which years have that wire, but I hope mine has it when I can add an aux battery.
Old Oct 15, 2018 | 1:48 PM
Yep, thats how a secondary will be charged and I somehow know all what is required. Just wondered if the solution was oem.
Old Oct 15, 2018 | 1:56 PM
StanVan's Avatar
15 Year Member
That wire is supposed to be in the harness somewhere. I would guess it is under the drivers seat, because it makes sense when the aux battery is on the frame under the floor, just behind the driver. And there's a tap for power large enough to handle charging there as well.
Old Oct 15, 2018 | 2:14 PM
Oh I will look for it. But isolator and fuses and all required hardware will have to come from Amazon, I guess,
Old Oct 15, 2018 | 2:25 PM
StanVan's Avatar
15 Year Member
There are cheap RV charger relays that will isolate just fine. You might find one with a fuse built in.
Old Oct 19, 2018 | 12:32 PM
Yep, thanks.
Amazon has some nice prebuilt kits.
Old Oct 19, 2018 | 6:09 PM
ChevyVanMan's Avatar
Always run my trucks positive to positive , neg to good grounds. Never any problems and blessing of techs. Isolater relay is good though, think one that is timed though before closing contact with second battery.
Ken
