"Service Stabilitrac Soon"
Old May 5, 2018 | 7:02 PM
StanVan's Avatar
15 Year Member
Default "Service Stabilitrac Soon"
This is a new one. I've had the message before, and upon research,it can happen when you use one of those Bluetooth OBDII devices (like I sometimes do). I unplug it, plug it back in and it works just fine. A known anomaly.
But it happened twice, yesterday and today, and I wasn't using the OBDII thingy (technical term). I plug up the OBDII device, scan for codes with Torque Pro, and no codes. I shut the engine off, restart, and the message goes away.
Anybody else have this happen? Any ideas on what it could be?
Old May 5, 2018 | 7:46 PM
Twscarp's Avatar
I believe it's called a scanner or an interface, but you mentioned it happened twice without the device plugged in right? Maybe try a computer reboot.
Old May 5, 2018 | 9:54 PM
ChevyVanMan's Avatar
Happens when your too quick in a turn, spin tires etc. Stop turn Van off for 30 seconds restart..
Old May 5, 2018 | 9:57 PM
There might be some clues here:
https://chevroletforum.com/forum/tah...control-45015/
Old May 5, 2018 | 10:16 PM
By the way it is in the manual too :-) Wait to you engage engine braking.!!!!!!!!!!
Old May 6, 2018 | 8:08 AM
StanVan's Avatar
15 Year Member
One of the times was in a parking lot, and I had just clipped a curb, and probably spun the wheel a bit. When I first had the van, I did spin a wheel one time getting into traffic, and it didn't give the message.
Old May 6, 2018 | 8:34 PM
Won't do it much, just certain situations. My GMC 2500 did it once on a gravel road.
Old May 6, 2018 | 11:46 PM
StanVan's Avatar
15 Year Member
Happened again, in the driveway, backing it from the front into the back yard. I'll try a reboot tomorrow.
Old May 7, 2018 | 11:08 AM
StanVan's Avatar
15 Year Member
Okay, that was scary. Never done a reboot before, and when I went to start it afterwards, it had to "think" about it. Second start was fine. I'm off to run errands. I'll report later.
Old May 8, 2018 | 3:05 PM
Reboot ?
