side door lower hinge Cracked
Old Aug 26, 2022 | 9:46 PM
the Brain's Avatar
Default side door lower hinge Cracked
side door lower hinge Cracked.just my luck I finally get a van w/ driver side side doors
And this happenes dam.
03 GMC Savana I’m thinking the hinge pin seized then the actuel hinge cracked.
1.on a 03 is the whole hinge bolted on or welded on?
2.Am I forced to buy expensive hinge pins w/ zerk fitting to avoid this cracking in future?
3.even if I had the hinge welded, seams extremely difficult to remove the pins.
One y-tuber was using a tool that fired a 22 shell to remove the pin, like couldn’t I hit pin w/ a screwdriver from underneath pin?
4. I liked the video where the man drilled 2 small holes where the pins sits sparyed wd40 and was done.wonder how often he sparys.
5.ebay apparently has the hinge pins at a reasonable price.have welded or JB cold weld expoxy an ebay pins. Need a easy way to remove pins? Please advice thanks
NEW FOR 96-19 CHEVY GMC VAN SIDE CARGO DOOR HINGE PIN & BUSHING REPAIR KIT | eBay
Old Aug 27, 2022 | 11:24 PM
William Kisselstein's Avatar
Back during the cash for clunkers thing I bought power window doors off a '97 Express to flip and I don't recall doing anything special to remove the pins, just ran a flat punch up from the bottom and they came right out. But, nothing was broken and those doors opened easily. If they're frozen you might have to drill them out.
If you have to drill them I'd say start with an HF step bit, they work much better on metal than a regular one, the only problem is once you get to the step that's the size of the hinge pin you'll have to go to something else.
Hinges were welded on and that was the only way to remove. Maybe you could drill them and use bolts to attach but I don't know there is anything under then to bolt into, it may just be the body sheetmetal there.
Old Aug 28, 2022 | 8:42 PM
the Brain's Avatar
not the front doors the side door and evedentalley it's a problematic hinge the grease dries up,previous owner must have forced a ungreased door and snap goes the weasle of a hinge.
there's a $45. hinge pin removal tool.
cracked side door hinge 03 savana. the ebay hinge appears to be attached w/ 3 bolts, at $63. it's kindof pricei, for a pin w/out a zerk fitting. it's either relace hinge or have hinge welded.I'd like to unbolt a used hinge and replace pin, sean a few videos on this problematic hinge.if hinge was in a vice could the orginale pin be beaten out or drilled out?I don't like the idea of a $45. tool to press out a pin. I really liked the video where the man drilled to holes into hinge and sprayed wd40 on pin.
1st image is of prefered pin w/ zerk 2nd image of hinge & pin w/out zerk.
I'd like to unbolt used hinge.
the ebay seller only has the right door hinge so a left side door mite be diffacult to obtain.
do you think JB cold weld expoxy is stronge enought?
thanks for hinge advice edit still waiting on advice on my other longish thread.
Old Aug 28, 2022 | 9:39 PM
I don't know why there would be any difference in the side door hinges from side to side. Worst case, a right side rear would be the same as a left side front (for the middle doors).
But they're all welded on and you take the door off by removing the pin, it doesn't matter which door.
I've never used the JB weld but it can't hurt to try. Either it will work or it won't.
My 02 has a stiff hinge and I hit it with the PB Blaster once in a while, then swing the door back and forth to work it in. Seems to work for a few months, then it gets stiff again. Might be worth a shot to get the pins looser to remove them.
Old Aug 21, 2025 | 9:07 PM
Vingo's Avatar
Default Same issue!
I HAVE cracked hinge but not total loss. Wondering if you got pin out? Im lubing with kroil and seeing if that may help. I dont know if the pin popper tool is worth it? Mixed reviews.
Old Aug 22, 2025 | 8:30 AM
Derrick71's Avatar
I know this is an old thread but for anyone else reading I would say this. I would NEVER consider attaching a door hinge with JB Weld or any sort of epoxy. It WILL fail and fail all at once with no warning. The entire door will be on one hinge which will break or tear away from the body and probably injure whoever opens it.
Old Aug 22, 2025 | 8:48 AM
Derrick71's Avatar
I would call a few body shops and see if they have the tool and will remove the door for you. If you offer cash they'll probably do it for less than the cost of the tool.
I'm all for investing in tools and doing things my self but sometimes it makes sense to pay someone else. Especially if you aren't going to do it again. They know how to use the tool AND how to support the door during the process.
Removing a door can be tricky and do a lot of damage if it gets away from you. You'll have to jack the door up to take tension off the pin and ALSO support it so it doesn't twist on one hinge causing more damage and hazard.
Old Aug 22, 2025 | 10:31 AM
Vingo's Avatar
Default Pin popper
I finally found a shop that will try to do it after I buy the tool for them. Hoping to win bid on ebay for 30 bucks. The guy also showed me these vans used a glue on the hinge to attach to body so a pain to replace if broken so I'm trying to avoid that. Gettimg kroil today to soak in and see if that helps. The pins are not cheap to replace now either and this damn hinge is costing a ton for what should be a simple job. 😪
You can see the crack from last owners pulling on door.
Old Aug 22, 2025 | 10:33 AM
Vingo's Avatar
jfonod
Sep 19, 2024 11:54 AM
Redevilrxp
46
Oct 31, 2019 5:27 AM
gojaxon
Feb 15, 2011 8:32 PM
2007BURB
Jun 13, 2009 12:52 AM
jcw1500wt
Mar 24, 2008 11:07 PM
