Smog check
Old Mar 30, 2025 | 10:51 PM
RobsRV's Avatar
Default Smog check
I took my RV in for a smog, and the guy hooked up what appeared to be (scan tool with bidirectional controls), and lo and behold, I have a check engine light I didn't have before. Is it possible for someone to use a bidirectional scan tool to for example, set your purge valve open or change other settings to cause the check engine light to come on and give you P0171 & P0174 codes Seems to me the only thing that should have been hooked up to my OBDII port was the smog test machine
Old Apr 1, 2025 | 12:53 PM
RobsRV's Avatar
More to the story, I hadn't driven the van, which happens to be an RV, for 5 months, and the battery was dead and unrecoverable. I replaced it and drove the RV for about 30 miles with no check engine light. Then when I took it in for smog, the guy said you're running lean I said but I have no check engine light he says you will and lo and behold, right before my eyes, the check engine light comes on. He had his own computer, which I assume to be a (scan tool with bidirectional controls). so maybe you can see how I might assume he did something. I guess next time I take a vehicle in for smog I should use my symple scan tool and check for errors and run a test. I probably should drive that RV 5 of 10 miles once a month, too
Top
RobsRV
May 20, 2025 7:42 PM
Bolander
Feb 14, 2020 4:09 AM
tlcook1
May 31, 2011 2:22 PM
Charliedog
Cruze
Apr 23, 2011 9:31 PM
Revredneck
Feb 22, 2007 1:56 PM
