I have a strange behaviour with my headlamps (or head and rearlamps). When the ignition is on (engine off) and headlamps are on and I use the turn signal everything works fine.
However when I have the engine running and the headlamps on and I use the turn signal, the headlamps go off and then on again, off, on... When I remove the relay, which is next to the turn signal relay unter the steering wheel, all is fine and the lights stay on, when using the turn signal and engine is running.
I have made a
If you trace your problem to a bad relay you might want to review THIS post and consider filing a complaint with NHTSA (link in the post)
as this may be a defective part problem.
NHTSA can order a recall but there needs to be a number of complaints on file.
