Strange electrical problem
Old May 21, 2008 | 9:42 PM
doctort's Avatar
Default Strange electrical problem
I have a 2005 Express 3500 6liter. When the ignition is off, the instruments light up. When it's running, they still light up, plus... ABS light is on, no horn, no cruise control. It starts up and drives OK otherwise. Fuses check out OK. Got any ideas?
Old Jun 16, 2008 | 12:16 PM
stewdogg's Avatar
Professional Mechanic
Default RE: Strange electrical problem
I would first try pulling the cover off of the PCM and checking to make sure that you don't have any exposed wires that could possibly short on another wire or metal. Could also possibly be some wires from the ignition shorting out somewhere along the line.
The last option I can think of right now is to check all of your grounds to the chasis because when not properly seated they can cause problems... I have also had a burnt out taillight make my dashlights come on when I would push the brake pedal. Bad grounds can cause some funky "unexplainable" issues.
Old Jun 16, 2008 | 3:26 PM
shawnvw's Avatar
Banned
+1 on the bad ground idea
If a circuit can't ground through its intended ground point, it will feed back through other circuits till it finds a ground
schmidt16
Jul 29, 2013 9:45 AM
oipunk99@hotmail.com
Apr 24, 2013 4:57 PM
CountryMusicCTD
Apr 22, 2012 9:49 PM
ndh87
Mar 10, 2009 6:14 AM
k443
Jun 8, 2008 7:35 AM
