Suspension Rubber Bumper
Old Feb 29, 2020 | 6:30 AM
toolhore's Avatar
Default Suspension Rubber Bumper
Pictured is the Rubber Bumper on The A frame of my 2007 2500. Both side look like this and I believe this is the cause of mt intermittent shimmy.
As You can see its in horrible condition. Are these replaceable ?
Old Feb 29, 2020 | 1:03 PM
Maybe. Did you call some part dealers? Search online?
Try rockauto.com
Old Feb 29, 2020 | 3:15 PM
Irish_alley's Avatar
I'm here for the party
did you search for "bump stops" on google?
Old Feb 29, 2020 | 6:12 PM
toolhore's Avatar
Thanks Fellows, I did not know what they were called. Now that I do I will dig around the internet and see what comes up. Will update when I find something.
Old Feb 29, 2020 | 6:19 PM
can't see how a bump stop can cause a shimmey. post what and when this is happening.
Old Feb 29, 2020 | 8:23 PM
toolhore's Avatar
Its the lack of bump stop thats the issue. Mine are totally disintegrated, therefore there is nothing to absorb certain road conditions. The shimmy occurs on some road surfaces that are not smooth, it happens mostly under washboardy road surfaces. My front shocks are high end Gabriel and only 2 years old. There is no slack in other component that I can detect. I mentioned this issue to an experienced mechanic and the bump stocks were the first thing He mentioned.
Old Feb 29, 2020 | 11:37 PM
the purpose of bumps stops are to protect the suspension from damage when bottoming out.
Old Mar 3, 2020 | 6:32 PM
toolhore's Avatar
Problem Solved. I purchased new Bump Stops at Auto Zone [$36.55 for a pair] and have just installed them. Very, very easy to install. Just pop the old ones out with a screw driver and push the new ones in with same screw driver. I took vehicle for a short drive and notice right away that I could not feel the road surface in the steering wheel. I will know more tomorrow on my commute to work, 30 miles each way.
Jake Abrams
Aug 21, 2020 10:57 AM
JDFETT
Jan 9, 2016 12:39 PM
s34n
Aug 26, 2014 12:59 AM
CapitalCity_Z71
Feb 3, 2014 4:10 PM
CptDondo
May 5, 2012 6:26 PM
