Swapping g80 into non g80 diff
Old Jan 7, 2021 | 6:53 PM
Rob B's Avatar
Default Swapping g80 into non g80 diff
Hi folks
i have parts van 2001 gm van with g80.
i have 2007 with open diff .
Question: can I swap ?
Thanks
Old Jan 8, 2021 | 7:53 AM
Triaged's Avatar
Originally Posted by Rob B
Hi folks
Thanks
Both 1500's? Both 2500's? Have you at least looked at the diff cover to count the number of bolts on both?
Old Jan 8, 2021 | 8:39 AM
Rob B's Avatar
Default Diff swap
They are both 3500 , 10 bolt
2001 is extended with rear drums (huge drums!)
Old Jan 8, 2021 | 8:40 AM
Rob B's Avatar
Default Diff swap
I will count the bolts .
Old Jan 10, 2021 | 6:09 AM
William Kisselstein's Avatar
Rearend on this should be a 14 bolt cover semi-floater.
I don't know what the newer vans use, I would think normally it's easier to just swap the entire rearend assembly over, but I think the 2007 has disc brakes all around.
One way to check interchangeability would be to go on Rock Auto and check differential specific parts for interchange across those years. It is possible however the housings are different internally from open to G80.
Old Jan 10, 2021 | 7:00 AM
Rob B's Avatar
Default Swap
The 2001 (g80 With drums)
has more bolts on diff ,looks bigger , and had different shaped diff cover .
so looks like I would need Professional mechanic shop to put new unit in Which would cost too much for this Adventure (probably around $1500 )
looks like I’ll just get a bag of salt and shovel for know .
Thanks for advices
Nycstev
Dec 20, 2020 1:21 PM
ikane
Feb 11, 2016 11:05 PM
countryjeff
Mar 27, 2015 8:45 PM
kanatuna97
Astro
Dec 22, 2014 11:07 PM
Willys
Apr 17, 2014 12:18 PM
