Temperature problem
Old Feb 4, 2011 | 4:23 PM
iCrash's Avatar
Default Temperature problem
First a little background... thermostat, coolant, and temp sensor are about 2 years old.
When I start the van and let it idle the temperature will rise almost to redline and stay there for a minute or two and then steadily decline to normal operating temperature. It does this regardless if I am moving or not. Sometimes after it has returned to the normal temp it will rise again to just below redline and then decline again. It never actually gets to the red zone of overheating.
I've heard that it could be
A) fan clutch
B) air in system
c) bad thermostat
D) Internally collapsed hose
E) failing water pump
F) inaccurate gauge
Old Mar 9, 2011 | 1:07 AM
rico's Avatar
Default have you fixed this problem yet?
did you change the radiator car? what degree thermostat did you use?
Old Mar 9, 2011 | 6:56 AM
iCrash's Avatar
I replaced the thermostat a few days ago. It looks like all is well now
Old Mar 9, 2011 | 8:12 PM
RacerX's Avatar
yep, bad thermostat
biglg
May 21, 2021 10:08 PM
TESE
Aug 9, 2015 4:21 PM
cabinet
Dec 15, 2010 9:31 AM
meshk57
Jul 13, 2009 8:16 PM
tcraig
Sep 7, 2006 1:34 AM
