Tranny temperature Switch location
Old Nov 11, 2018 | 9:39 AM
Ron6519's Avatar
Default Tranny temperature Switch location
Any reason I can't install a temperature switch on a 4L60-E tranny in the pressure switch port by the safety neutral switch? Both the return line and the pressure port are about the same height.
Thanks
Ron
Old Nov 11, 2018 | 2:23 PM
What kind of switch? What for?
Old Nov 12, 2018 | 7:57 AM
Ron6519's Avatar
A temperature switch for the transmission. So I can keep track of it.
Old Nov 12, 2018 | 3:27 PM
I'm confused. A switch turns things on and off. You mean a sensor? We covered that in your other transmission cooler topic.
Old Nov 13, 2018 | 7:14 AM
Ron6519's Avatar
Right, temp sensor. I started a different thread so it was separate. Got the advice from there, so thanks.
Ron
Old Nov 14, 2018 | 10:19 PM
post your model year, engine and trans. Most newer electronically controlled transmission already have the sensor even if its data is not displayed on the dash. If could be as simple as a cluster swap and reprogramming. Other options are a programmer or display device that connects at the dlc port.
Old Nov 14, 2018 | 11:42 PM
You have an interesting concept of 'simple'
Old Nov 15, 2018 | 8:41 AM
Ron6519's Avatar
2001 GMC 2500 Savana Van with a 5.0 liter engine and a 4L60-E transmission.
Old Nov 15, 2018 | 9:09 AM
Ron6519's Avatar
What type of programmer and what's a, "dic" port. And where is it.?
Old Nov 15, 2018 | 11:18 AM
He said DLC (diagnostic link connector). It's the same port your Bluedriver plugs into above the parking brake, and by "display device " he means a scan tool such as your Bluedriver.
