Trans cable adjustment???
Old October 12th, 2017, 10:24 PM
  #11
canucklehead's Avatar
FYI. I had my key freeze in the crank position once when starting my 2002. There I was sitting there with the engine running, and the starter sounding like it was trying to grind the flywheel down and inch or so.
I cranked hard on the key to just barely get the starter to quit, and limp to a dealer for a replacement key cylinder......
I hope yours does not do that to you, and also that it is not contributing to your issue.
Old October 12th, 2017, 10:28 PM
  #12
DWB
DWB's Avatar
Yesterday, 11:34 PM #9
canucklehead
Thanks for the detailed thing you found on the web,, Do you think that is for a 2000 express 2500 ?? Just wondering. thanks.
Old October 13th, 2017, 12:04 AM
  #13
I posted it because the pic i saw showed the same trans cable and snifter lever on the tranny as my 2002......
Old October 13th, 2017, 12:10 AM
  #14
DWB
DWB's Avatar
Thanks, I thing the 2002 is the same too.
Old October 13th, 2017, 9:09 AM
  #15
Twscarp's Avatar
Originally Posted by DWB
Now it after dark here in the 57th state so tomorrow.
In Oregon?
Old October 18th, 2017, 10:06 PM
  #16
DWB
DWB's Avatar
Okay at work today again it stops going into park I thought I had this remedy but I didn't, so when I get home this afternoon I get up under my van and I investigate. I find the cable is held on with a ball and socket joint I really didn't know how it worked but I pulled on it hard enough and it popped off. Now I could manually click my transmission and it did go in the full range from Park to the lowest gear so I knew that was working now I unclipped my cable and pulled it out to the longest setting and it seemed like my cable was one inch short of reaching Park? Does anybody have any idea why my cable would seem one inch Short of reaching park when I have it fully extended???? man I need some help with this one!!!!!
This post this post has a text a talk-to-text warning be careful....,.......
Old March 23rd, 2018, 8:35 AM
  #17
Andwesse's Avatar
How do I adjust Parking brake on Chevy Spark 2009 model. Do I have to remove the drums or is there any other way?
Old March 23rd, 2018, 1:36 PM
  #18
This topic is about van transmissions. You are in the wrong place my friend.
Old March 23rd, 2018, 11:19 PM
  #19
DWB
DWB's Avatar
So it was my nurtal safety switch falling off that was messing everything up.. I used a zit tie to the steering column to fix it.
Old March 24th, 2018, 1:52 PM
  #20
DWB
DWB's Avatar
That van had messed up valves and had to go to the scrap yard,, I now have a 2006 GMC,,, can I still be at this forum of is there a GMC forum???
