Transmission cooler line plumbing '08 Exp 3/4 Duramax
Old Jun 28, 2021 | 12:46 PM
andrewgouin's Avatar
Default Transmission cooler line plumbing '08 Exp 3/4 Duramax
Has anyone else done this? Gotta admit, I'm having a hard time with it, what is the normal procedure for running these lines? I really am at hard point here, the fitted lines don't want to pass through, I'm hoping I don't have to remove any real elements.
Old Jun 28, 2021 | 2:19 PM
unplug return line from radiator and plug it into aux cooler output. Install new short line from radiator output to aux cooler input.
Old Apr 28, 2025 | 8:53 AM
Acheron's Avatar
Default Just did mine
I just got finished doing mine feed the line from underneath towards the radiator. If you're having trouble removing the old lines from the radiator cut them off a couple inches from the radiator and unscrew the whole thing. Then you can remove the line easy. Then screw the connector back in tight before you reinstall.
When you reinstall the new lines be sure to put the clips in first then just push the new line in until you hear a click.
dexstrom
Jan 14, 2021 9:15 PM
in2pro
Jul 23, 2015 11:55 PM
trucker9
Mar 4, 2014 10:41 AM
thomas101
Uplander
Jun 11, 2012 7:14 PM
