Is the transmission housing in a G-series different from a C/K OBS?
Old Sep 27, 2023 | 2:33 AM
89Vandura's Avatar
Default Is the transmission housing in a G-series different from a C/K OBS?
I read this somewhere, that the transmission housings in G-series vans are longer than the housings in C/K OBS trucks. Does anyone know if this is true?
I have a 350 with a 700r from a Vandura and I'm thinking of saving it for an OBS truck/Suburban/Tahoe/Yukon.
Old Sep 27, 2023 | 9:07 AM
RoadTrip's Avatar
The K transmissions have a shorter tail housing to accommodate the transfer case. The C transmission should be the same, but you’ll want to check gear ratios and mechanical vs electrical shift control connections.
Old Sep 27, 2023 | 12:41 PM
89Vandura's Avatar
Is the longer tailhousing on 2wd applications something that can be removed?
Would the gear ratio and mechanical/electrical shift mechanisms prevent my 1989 transmission from being usable in certain vehicles?
Old Sep 27, 2023 | 12:50 PM
RoadTrip's Avatar
Your questions would be better asked in a GMT400 forum. Perhaps someone has done this application and can speak personally about it.
The tail shaft housing encases the tail shaft itself, so both would have to be changed of you were to apply a 2wd trans to a 4wd trans.
Thomas Neels
Jan 16, 2022 2:22 PM
cannibal carl
HHR
May 20, 2021 10:08 AM
Davpmars
Jul 15, 2017 8:03 AM
chad666
Oct 19, 2014 6:53 AM
