Trim Restore
Old Jan 2, 2019 | 8:15 AM
  #11
StanVan's Avatar
15 Year Member
Just don't put it on the inside of the handle. But yeah, it has been suggested that it can restore some plastics.
Old Jan 2, 2019 | 10:40 AM
  #12
tsoleno's Avatar
There is a black molding and trim restore out there. I've used it in years past though I don't recall if it was a Mother's or a pro product. For me it worked well and lasted pretty much a year before re applying. It is applied like wax, rubbed in and wiped /buffed off. I've used it on cowling and trim to deal with the oxidation.
Old Jan 2, 2019 | 12:42 PM
  #13
StanVan's Avatar
15 Year Member
I hate it when a word escapes me. Oxidation is what I wanted to say. WD can help with oxidation of plastics.
Old Jan 2, 2019 | 2:56 PM
  #14
I predict that it doesn't last very long.
Old Jan 2, 2019 | 3:26 PM
  #15
StanVan's Avatar
15 Year Member
Probably longer than you may think. It's not just a cosmetic fix. It should actually remove at least some of the oxidation, so as the WD evaporates, the oxidation shouldn't return just because the WD isn't there. WD isn't the best lubricant, but it is a good cleanser. It's quite good at removing adhesive from stickers.
Old Jan 2, 2019 | 5:00 PM
  #16
The oxidation will return because the plastic will continue to degrade.
Old Jan 2, 2019 | 5:47 PM
  #17
StanVan's Avatar
15 Year Member
In time, yes. But it won't reappear the minute the WD evaporates.
Old Jan 3, 2019 | 10:47 AM
  #18
GeneveConversionVan's Avatar
I applied yesterday night WD. So far looks better.
Old Jan 4, 2019 | 1:58 AM
  #19
dberladyn's Avatar
If mine go like that, I will just wrap them in flat black vinyl car wrap. I had a large roll of it to black out my windows completely from the inside and cover things I make.
Seriously, go check out vinyl carp wrap. You get a million different shades, even wood grains. It's actually how the factory dresses up vehicles and then charges $10,000 more.
Old Jan 4, 2019 | 8:55 AM
  #20
yep. I’m thinking either vinyl or plastidip. I just tried WD as I have a can handy and wanted to give it a try.
