Turn Distributor
Old Jun 6, 2014 | 12:53 PM
AristotleAquinasRand's Avatar
Default Turn Distributor
Hello,
I took my 89 G-20 cargo van to my favorite long time mechanic for a new flywheel and serpentine belt. After picking it up the next day I started it up and it sounded and drove terrible. I turned it around and brought it back. They took the dog cover off and said that they accidentally knocked two of the spark plug cables off of the distributor cap. Ok, no harm done. I started it up and although it was not as bad as it was it was still rough. I checked the firing order, changed the spark plugs, distributor cap and rotor but it sounds like it may be out of timing. I was wondering if the mechanic rotated the distributor and if so can I go back and rotate it back in position? The reason I suspect the mechanic is because I don't see how someone can knock two spark plug cables off of a distributor cap by removing a dog cover.
Thanks for the help. I use my Chevy for work and am proud to keep it on the road.
Jim
Old Jun 6, 2014 | 6:36 PM
greenfire's Avatar
Yes, check and see if the distributor is loose. Turn it a little at a time until untill it smooths out. Ideally should be done with a timing light or vacuum gage. But it they just nudged it... a little adjustment might do the trick.
Old Jun 8, 2014 | 12:24 PM
canucklehead's Avatar
More than an inch in either direction and it would run at all. It could be a timing issue as Greenfire says.
Old Jun 8, 2014 | 3:18 PM
I took it to a mechanic who has a similar vehicle, he put his timing light on it and it read zero. That is just what the manual recommends.
Thanks for the good advice,
Jim
G T Igofast
Sep 3, 2013 3:46 PM
Mr. Vann
Nov 25, 2009 7:24 PM
Dmoney6
Jun 24, 2008 9:49 AM
Manor_Mullet
Apr 28, 2008 2:13 PM
silverado01ls
Jan 4, 2007 6:36 PM
