Turn signals blink fast
Hi,
Recently my voltage gage showed about 12V (normally 14V) and the battery light was lit. I assumed I had a shorted battery cell and replaced the battery. The voltage now shows 14V when I am driving but when I come to a stop (with the van in gear) the voltage drops to just below 13V. Also the turn signals flash at normal speed when the voltage shows 14V (while driving) but the flashing speeds up when the voltage drops to 13V (when at a stop sign for example).
Are there any experts here that can offer some insight. I am afraid that something else (besides the battery) has failed.
Thank you,
Jason
Thank you,
Jason
The alternators in those days were the two-wire kind, one wire to the battery positive terminal and the other to the I/P cluster. It's grounded through its housing, through the engine block, and then to the battery negative terminal. With the engine idling, carefully check the voltage between the BAT post on the back of the alternator and a clean metal surface of the engine block. I think you should see at least 13.2V. If not, the alternator is not keeping up with the demand.
wjm40a
Uplander
10
September 5th, 2018 9:35 AM
megana
October 21st, 2013 6:00 AM
boneskeys
July 31st, 2011 12:27 PM
Manor_Mullet
April 28th, 2008 2:13 PM
