Van-ity
Van-ity
Ok so I have a 90 G20. I had a bad cell in the battery. So I had to make do with it jumping it off most of the time to come and go. On the way to work, I hear this loud shrill humming and the van cuts off, I popped the hood and the battery had exploded.. battery acid everywhere.. so I brought it home and replaced the battery. Clunk. Nada. Took of the starter. Tested it, it failed. Thought to myself, boom figured it out. Nope, installed new starter and did the shimmy dance with it. And the most I get are a clunk, or rapid click click clicks.. I don't know what to do at this point. As I have looked at the flywheel and the teeth seem to be ok. But it shut off quickly and I'm thinking maybe it got stuck in rotation or in cycle. This thing is my home most of the time as it's solar powered for living purposes, and it's my daily. I'm mechanically reclined so please sit me up here. Please help.
mechanically reclined 😆 me too.
Do you have a multimeter? Try probing voltage at the ignition switch, starter relay, starter motor etc.
Make sure battery cables are clean and tight. Check the ground strap on the engine too.
HerzeleidMeister
20
October 31st, 2019 2:23 PM
likearolingston
January 12th, 2012 11:24 PM
Brian Ahlers
November 26th, 2011 7:29 AM
