Wheel offset Chevy vs GMC
Old Mar 26, 2024 | 9:32 PM
jjrbus's Avatar
Default Wheel offset Chevy vs GMC
I have been dealing with a highway wandering issue. Have had 3 recent alignments and had the front end inspected 6 times. One mechanic said I need new idler arms. 5 to one so. Since I bought the van, actually a Cut Away converted to a Roadtrek RV. 01 Chevy 3500 8 cyl SRW.
I have swapped out the OE steel wheels for Aluminun. Almost the same except my van shows 18mm offset and wheels are 28mm. 2 year old tires with 10k Bridgestone V-steel 245 75 16 load range E, run 65 psi in the front and 80 psi in the rear.
Anyway decided to try different tires and wheels. Picked up a couple wheels today for $10 each from a 2000 GMC Savana 3500, gotta be the same wheels right. SizeMyWheels.com shows that the GMC wheels have a 28mm offset. I have looked around as it seems that the GMC and Chevy would be exactly the same but I can find no reference to the GMC wheel offset except for refurbed wheels which show both the GMC and Chevy wheels with a 25mm offset. Anyone know the offsets or where to look them up?
Old Mar 26, 2024 | 10:46 PM
Triaged's Avatar
How about measure your wheels? The Dodge wheels on my van are 43.18mm offset. Why dismiss the mechanic that said you need an idler? Why not strap a video camera aiming at the idler and go for a drive?
Old Mar 27, 2024 | 7:15 AM
jjrbus's Avatar
When someone is told they need a repair they are almost always told to get a 2nd opinion, I have 5 2nd opinions, including an alignment specialist. I do not have an OE Chevy wheel to measure. Camera is a good idea.
Old Mar 27, 2024 | 8:04 AM
jjrbus's Avatar
After a couple hours on the internet attempting to find the offset I came across site's that shows the same part # for the Chevy and GMC wheel 09593585 and also the other vehicles it fit's. So will assume the 18mm offset on Size my wheels is incorrect. https://www.qualitybydilorenzo.com/g...dhcw%253D%253D
Old Mar 28, 2024 | 8:24 AM
Uncle Rico's Avatar
I find wheel-size.com is pretty reliable for OEM wheel info. I was going to suggest posting your issue on classbforum, but I see you already have an extensive investigation going there.
Old Mar 28, 2024 | 4:01 PM
jjrbus's Avatar
I post a bit here and there and stick with where I get the most input!
jjrbus
May 15, 2022 1:08 PM
FatFen55
Feb 26, 2022 10:25 AM
honda
Corvette
Jun 7, 2009 2:04 AM
honda
Mar 17, 2007 6:41 PM
