windsheild replacment
Old May 6, 2021 | 4:55 PM
JJAAYY123's Avatar
Default windsheild replacment
Help.
1983 G-30 camper I need to replace windshield. Cant find anyone in my area that will do it. Anyone able to guide my through the install ?
Thanks
Old May 6, 2021 | 6:21 PM
Trackvw's Avatar
Which area ?
I think its best to get a pro to do it , they have the suction cups etc
If it was me , I would go down to the junkyard area of town (wilmington) and there usually are a couple glass shops
Old May 6, 2021 | 6:47 PM
how is the glass secured by rubber seal or urethane? This must be done correctly as its a safety issue.
if its urethane...by the time you buy the tools required and the glass...you will be at the cost of a professional install. if you want to try it...eric the car guy has a glass install video.
if its a rubber seal
Old May 7, 2021 | 7:22 AM
Get a pro to do it. This is a big piece of glass and you could easily break it.
Old May 7, 2021 | 9:08 AM
hanky's Avatar
If you watch someone that does this every day, its a piece of cake. They have the tools , materials and experience to do a good job.
Not that you can't tackle it,,,,,,,,,,,,,,,,,,,,but if you start it, you might regret getting into something that can be very disappointing when things go wrong.
Old May 7, 2021 | 9:12 PM
JJAAYY123's Avatar
Thanks for all the responses. Problem is I cant drive van yet. I have old broken glass out and new one ready to go. I purchased gasket and it seems to be a combination of urethane and 2 gaskets. Gonna keep trying to find someone.
Old May 8, 2021 | 7:46 AM
Most of the auto glass companies will come to your place and do the installation.
Old May 8, 2021 | 10:00 AM
tsoleno's Avatar
Agreed with the glass company. At least with you having the glass out, you can deal with any rust in advance of them doing the work. On my 08, the glass guy told me they are seeing rust where the channel comes down off the roof.
Old May 9, 2021 | 4:10 AM
William Kisselstein's Avatar
1983 should be a rubber gasket, lay it in there with a string and use the string to pull the lip of the gasket over the window channel.
Later G-vans are urethaned in, 1994, 1995, not sure what year they switch.
Rebekah Morey
Jun 18, 2019 7:53 PM
lyleapgmc
Apr 4, 2016 7:43 PM
Adrian_L
Dec 15, 2014 12:52 PM
unckybob
Feb 13, 2013 3:12 PM
TahoeG8R07
Jul 16, 2007 7:39 AM
