Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
2002 Suburban Brakes Failed
Old Jun 24, 2017 | 5:19 PM
ericbikes's Avatar
Default 2002 Suburban Brakes Failed
I reposted this in the Suburban section- sorry. Newbie...
2002 Suburban 1500- been driving fine then all of a sudden brake pedal goes to the floor. Drove it home about 1 mile. Brake fluid reservoir almost empty. Refilled reservoir. Found right side flex brake line split all the way through and when I gave the pedal a few pumps, fluid leaking from the hose.
I replaced flex hose (OEM) and bleeder screw. Tried to bleed brake but no fluid coming out at all when pedal depressed to floor after pumping a few times. Brakes still go to floor. Do I need to now bleed all brakes starting from right rear and work way to driver front?
Or is there something else I need to be doing. I thought I would get at least some brake pressure, but I'm not getting any. Help?
