Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
88 Corsica issue
Old Feb 26, 2020 | 2:07 PM
SASQUACH_2020's Avatar
Default 88 Corsica issue
HI. I am new to this forum so here goes.
I have a 88 Corsica 2.8 EFi that will run fine for awhile until warm. After,depending on the outside temperature, it dies after running from 20 minutes to 2 hours. It can be restarted and will run for at most a minute then dies again. After a couple of retries it will not start. If I wait for the engine to come to ambient temperature it will restart and the cycle starts again. There no error codes.I found one vacuum leak in the intake and repaired it. One thing i did notice is that when the cooling fan starts the engine stumbles until the fan is up to speed. When it stop the engine runs smooth until it again just stops. Has anyone had this problem? If so what was the fix? Any help is appreciated. Thanks
Old Feb 26, 2020 | 3:20 PM
Irish_alley's Avatar
I'm here for the party
could be the ignition module. a parts store might be able to test but make sure they test it a few times to heat it up
Old Feb 26, 2020 | 4:02 PM
Default 88 i
That's what I thought too. I replaced it and the issue is still there. I did have that in the past.
Old Feb 26, 2020 | 4:43 PM
kevinkpk's Avatar
May sound odd, but when was the cooling system flushed? I had a new 88 Corsica with 4 speed manual, but that was awhile back.
Old Feb 26, 2020 | 5:49 PM
Due to my replacing the motor mounts and had to remove the radiator, it is all new coolant. This problem has been going on for about a year now.
Old Feb 26, 2020 | 9:42 PM
have you checked the fuel pressure?
Old Feb 27, 2020 | 3:35 AM
Yes.It is in specs per the manual engine running and not.
Old Jul 14, 2020 | 10:42 AM
IanPayne's Avatar
I have the same problem
Jerad
Site Feedback
Oct 25, 2017 10:52 PM
blu93cavalier
Nov 15, 2005 9:27 PM
playa69
Sep 15, 2005 12:35 AM
