Forum Notice Stop in here to get the latest on CF happenings! This is also the place to get some information about site usage and the rules of the forum. Only staff and those permitted by the staff may post a new topic in this section. For permission to post something here, contact EvansBlue.
bottom end knock?
Old Jan 13, 2020 | 4:58 PM
JoshuaStanley84's Avatar
Post bottom end knock?
i recently rebuilt a 1998 5.7 vortec. from day one i have had a loud knock coming from the motor. i've played with the rockers and eliminated adjustment issues. the knock sounds louder under the truck and seems to be coming from the oil pan. the knock will often disappear for a few seconds then return or at the least quiet down when put into gear. it drowns out when under load but i hear it because i know its there. i removed my flex plate cover and check the plate/converter bolts and they are tight with no scars.also in dents in oil pan. when i pulled the flex plate cover i found a little more fresh oil than i wanted to see so im not sure if this is b/c of whats going on with the knock or not. any help would be greatly appreciated. attached is a video
Old Jan 18, 2020 | 5:02 PM
Little Bear's Avatar
Last time I had that it was a cracked flexplate. Worse part is you probably won't be able to see it without pulling the trans.
Old Nov 14, 2021 | 4:25 AM
raehzrh's Avatar
Nox/ vidmate vlc
Old Nov 15, 2021 | 3:53 PM
Welcome to the forum Joshua. If you haven't already done so, repost your information in the correct truck section of the forum and you will get more views and possible answers.
dconrads
Apr 15, 2019 10:10 PM
Patches
Site Feedback
Nov 28, 2017 12:00 PM
Dustinschevy
Feb 25, 2017 12:38 PM
SteveOmac25
Site Feedback
Mar 5, 2015 5:13 PM
vkrandoff
Mar 2, 2013 10:02 PM
