88 Corsica issue
88 Corsica issue
HI. I am new to this forum so here goes.
I have a 88 Corsica 2.8 EFi that will run fine for awhile until warm. After,depending on the outside temperature, it dies after running from 20 minutes to 2 hours. It can be restarted and will run for at most a minute then dies again. After a couple of retries it will not start. If I wait for the engine to come to ambient temperature it will restart and the cycle starts again. There no error codes.I found one vacuum leak in the intake and repaired it. One thing i did notice is that when the cooling fan starts the engine stumbles until the fan is up to speed. When it stop the engine runs smooth until it again just stops. Has anyone had this problem? If so what was the fix? Any help is appreciated. Thanks
