01 Silverado starting problem
Old Oct 30, 2013 | 3:41 PM
txduckman4's Avatar
Default 01 Silverado starting problem
Truck sometimes will start first time, most times takes 3-4, up to 8 tries. Been doing this over a year. Changed fuel filter, but didn't help. Once it starts it runs good. I would think that if the fuel pump is bad it would have shut down by now. It is a 1500 5.3L. Would appreciate any feed back.
Old Oct 30, 2013 | 10:36 PM
The check valve in the fuel pump assembly is bad. It lets the fuel drain back into the tank when not running.
Old Oct 31, 2013 | 2:55 AM
Jeff Collision's Avatar
Might be you have a small leak in the fuel system that makes the system loose pressure. So the engine has to crank longer to re pressure the fuel system again. You wouldn't have a problem after starting because the system is still holding pressure for that short period of time. Check if you have any problem in the Fuel Pressure Regulator, if you want to replace a new one, check with Buy Auto Parts - Fuel Pressure Regulator
Old Oct 31, 2013 | 3:23 PM
txduckman4's Avatar
Thanks, will check it out.
Old Oct 31, 2013 | 3:26 PM
txduckman4's Avatar
fire165
11
Aug 23, 2011 10:29 PM
Laketruck
Mar 19, 2008 4:48 PM
dude1987
Oct 21, 2007 11:05 AM
ffarv
Apr 9, 2006 1:52 PM
