05 LS 5.3 Oil Leak
Old Nov 7, 2013 | 10:54 AM
StainlessHeader's Avatar
Default 05 LS 5.3 Oil Leak
I have an 05 LS with the 5.3 V8. There is a pretty bad oil leak that looks like it is coming from the oil filter. I put a new oil filter and oiled the gasket and cleaned the surface for the filter and everything looked good, but still there is a leak. I was thinking it could be the mount or the housing that the filter screws onto it may be cracked. I don't really know what to think. Any thoughts?
Old Nov 7, 2013 | 12:42 PM
Another possibility is that the o-ring from the old filter came off the filter and is stuck to the engine, and now there are 2 gaskets there. I ahve seen thgis happen on several occasions.
Old Nov 7, 2013 | 4:20 PM
pat pennstate's Avatar
are you using ac delco oil filters? could be a wrong filter or does the 5.3 have a extra capacity filter ?
Old Nov 9, 2013 | 6:53 PM
Tech's Avatar
Trace the oil to its highest point of where it appears to be leaking from and start from there.
Old Nov 12, 2013 | 3:53 PM
namu mac's Avatar
Does your truck have an oil cooler? If so, I think the lines attach to the block just above the filter.
Eric Sherden
Sep 24, 2013 1:21 PM
PastorK
Mar 1, 2010 9:09 PM
95wt
May 30, 2008 3:07 PM
trush
Jan 1, 2008 9:27 PM
larry_chip
Apr 24, 2007 11:46 AM
